My 1996 protege's temperature gauge is starting to go past its normal position into the hot range.
The check engine light is on. But it has been on for a while. Had the catalytic converter replaced, the plugswires etc.. replaced.
I suspect the cooing fan is not turning on. The car runs at normal temp on the highway, runs hot after acceleration. The temp gauge drops if the heat is turned on.
Any help is appreciated.
Jun 11, 2009 at 2:06 AM
