1996 Mazda Protege temp gauge is showing running hot
1996 MAZDA PROTEGE
174,000 MILES • 4 CYL • FWD • AUTOMATIC
LATROBE59
My 1996 protege's temperature gauge is starting to go past its normal position into the hot range.
The check engine light is on. But it has been on for a while. Had the catalytic converter replaced, the plugswires etc.. replaced.
I suspect the cooing fan is not turning on. The car runs at normal temp on the highway, runs hot after acceleration. The temp gauge drops if the heat is turned on.
Any help is appreciated.
Jun 11, 2009 at 2:06 AM
RACEFAN966
  • 5,029 POSTS
So is the radiator full? Have let it idle and warm up to see if the fan comes on when it gets to temp (not letting get overheated)? Does the engine fans come on when you turn on the defrosters? Get back to me and we will go from there.
Jun 11, 2009 at 3:33 AM
LATROBE59
the radiator is full. I checked to see if the fans came on after driving from work, distance about 30 miles. I let the car idle in the driveway, the fans did not come on in about 5 to 10 minutes.
Jun 11, 2009 at 4:03 AM
RACEFAN966
  • 5,029 POSTS
Do you know where the temp sensor is on the rear of the engine? If you unplug that will the fan come on? Have checked to see if the fans come on when you turn on the a/c or turn it on the heat and set it on defroster mode? Do you have a digital multi meter to ohm the temp sensor with? If so the unplug it (engine off key off) and ohm the sensor (not the harness) and give me the reading and the temp at the time do this when the engine is cold so you can give me the outside air temp. Let me know what you find here.
Jun 12, 2009 at 1:48 AM
