1996 Mazda Protege Engine does not respond when ignition tu
220,000 MILES • 4 CYL • FWD • AUTOMATIC
MOLEY
While driving home from work, a strong rubber burning smell became evident inside the car. The radio began to fluctate. It was raining and I had the wipers on, they started to act in an irratic fashion. The spedomator also was irratic. I made it home and turned off the engine right away. Now the car doesn't start. There is no attempt by the engine to tun over, however, the radio still works.
Can you help please?
Marion
Apr 4, 2009 at 8:17 AM
KHLOW2008
  • 41,812 POSTS
Hi Marion,
Seems you have a problem with the alternator which could be not charging due to belting or alternator faults.
The battery has been drained and is not strong enough to start the vehicle.
Check the beltings and pulleys for problems such as seized pulleys etc.
A jump start would be required. If the battery is weak, don't worry about for now, it will be recharged once the charging system is restored.
Apr 8, 2009 at 12:05 AM
MOLEY
Thank you so much for your quick response to my inquiry! My son took the car to a mechanic and had the alternator and the belt replaced. The car is working great now.
Thanks again, it's good to know that there are people out there who care.
Marion
Apr 12, 2009 at 11:11 AM
KHLOW2008
  • 41,812 POSTS
Hi Marion,
You are welcomed.
Of course we cares, that is the reason we are here.
Glad to be of service. Anytime you got a question, feel free to drop by.
Have a nice day.
Apr 13, 2009 at 1:10 AM
