1996 Mazda Protege Battery issue or something else?
135,000 MILES • 4 CYL • FWD • AUTOMATIC
JOMO826
I drove my car to work with no problems. I left for the day and my car wouldn't start. I didn't hear anything when turning the key and nothing turned on. The radio didn't work nor did the digital odometer or the radio or headlights. After a friend jumped the car it ran fine. I got it home turned it off and started it up again without an issue. The car has started with no problems the past couple of days. I do notice that when A/C is on the car drops below 500 RPM's and starts shaking. Also when i am sitting idle sometimes the TAC drops below 500 and the car shakes. I'm not sure If I need a new battery or alternator. Either way I don't think the car is getting enough power.
Aug 3, 2008 at 2:04 PM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:7165a3c230="jomo826"]Electrical problem
1996 Mazda Protege 4 cyl Front Wheel Drive Automatic 135000 miles
I drove my car to work with no problems. I left for the day and my car wouldn't start. I didn't hear anything when turning the key and nothing turned on. The radio didn't work nor did the digital odometer or the radio or headlights. After a friend jumped the car it ran fine. I got it home turned it off and started it up again without an issue. The car has started with no problems the past couple of days. I do notice that when A/C is on the car drops below 500 RPM's and starts shaking. Also when i am sitting idle sometimes the TAC drops below 500 and the car shakes. I'm not sure If I need a new battery or alternator. Either way I don't think the car is getting enough power.[/quote:7165a3c230]
Go by your local AutoZone and have them check your battery and alternator.
Is your check engine light on? If so have them pull codes they will do it free
Aug 3, 2008 at 2:08 PM
