1995 Mazda Protege Temp guage goes up at and heater temp ge
1995 MAZDA PROTEGE
83,600 MILES • 4 CYL • FWD • MANUAL
TVH2CARPROS
The temp guage goes up and the heater temp get hotter only at idle. When I drive it the temp guage goes down all the way and the heater temp goes down. I put in a new thermostat. It doesn't appear to be losing any coolant. Please help. Is it the heater core?
Dec 3, 2009 at 2:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check to see that your cooling fan(s) come on properly. let me know if they are working..
Dec 3, 2009 at 2:40 PM
TVH2CARPROS
Do you mean to make sure the cooling fan is on at idle? Actually I think the thermostat was bad or it has a problem with the install. It has to be the thermostat. It acts like the coolant is continually flowing.
Dec 3, 2009 at 2:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
they come on when engine reaches certain temperature. not always at idle, you can hear them kick in while driving as well.
Dec 4, 2009 at 10:58 AM
RAINALLDAY
  • 5 POSTS
[quote:3da0e654ae="tvh2carpros"]Heater problem
1995 Mazda Protege 4 cyl Front Wheel Drive Manual 83600 miles
The temp guage goes up and the heater temp get hotter only at idle. When I drive it the temp guage goes down all the way and the heater temp goes down. I put in a new thermostat. It doesn't appear to be losing any coolant. Please help. Is it the heater core?[/quote:3da0e654ae]
I have the exact same problem, did you find a solution yet?
Jan 1, 2010 at 4:31 PM
RAINALLDAY
  • 5 POSTS
I have the exact same problem, heats at idle, no heat when moving....
I'm thinking its a clogged heater core...
I see that getting to the heater core is alot of work...
Jan 8, 2010 at 5:35 AM
