1995 Mazda Protege Engine losing power
110,000 MILES • 4 CYL • FWD • AUTOMATIC
D63BRAVO
My 95 Mazda Protege after it warms up hesitates to go when I step on the gas. I push the gas pedal and it does not accelerate. The engine doesn't rev it just doesn't move and then it will catch. It acts as if it is not getting gas but I had it looked at and it doesn't seem to be a fuel problem. Any idea what it might be?
Nov 6, 2009 at 12:44 PM
  • 110,251 POSTS
Has the check engine light come on? Did they actually check fuel pump pressure?
Nov 6, 2009 at 3:42 PM
D63BRAVO
No check engine light. Not sure if they checked the pressure or not.
Nov 7, 2009 at 12:05 AM
  • 110,251 POSTS
Since the check engine light isn't on, I would have the fuel pressure tested. Here is a how to for checking it:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
You will need a gauge to check it. Most parts stores will lend or rent one.
Let me know what you find.
Nov 7, 2009 at 2:56 PM
