Crankshaft Position Sensor
HAZRAT001
Where in this particukar model is the sensor located and how would you recommend replacing?
What needs to be removed etc.?
Dec 18, 2009 at 5:13 AM
DOCFIXIT
  • 18,828 POSTS
Fairly simpl located on front engine just remove and replace
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_272.jpg
Replacement 1. Remove the undercover. 2. Remove the crankshaft position sensor. 3. Install in the reverse order of removal. Tightening torque: 7.9-10.7 N.m (70-95.4 in-lb) See diagram below
Dec 18, 2009 at 5:25 AM
BRAYDEN19
My Crankshaft positioning sensor went out on my Mazda I have the part, I just need to know where the part is located and how I fix it.
Jul 30, 2019 at 5:01 AM (Merged)
  • 75,988 POSTS
The CPS is on front of the engine
https://images.2carpros.com/forum/automotive_pictures/12900_cps_41.jpg
  • 31,937 POSTS
Hi there,
It is located on the front of the engine , now Mitchell 1 dose not give any details, but most of these sensors will be under the lower cam belt cover, it will be attached by a 10mm bolt (normally) and the loom will unplug.
mark (mhpautos)
