1995 Mazda Protege Cold start problem
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
MAZDA GUY
Dear Sir,
I have a 95 Mazda Protege with the twin cam 1.8 engine. Only when the engine is stone cold this problem exists.
I crank to start and it catches for half a second, then it wants to die, then before it stops spinning it catches again, goes up to high idle and runs fine.
Hot starts no problem, or even when it sits for 4 to 5 hours no problem. It will start fine and go up to high idle, come back down and run fine. Only when it sits overnight it will do this. The colder it is, the worse it does it. Never had to re start it, but it may get worse.
Nov 19, 2008 at 4:22 PM
BLACKOP555
  • 10,386 POSTS
i would check the Intake air temp sensor and the engine coolant temp sensor and compare the resistance values of them with eachother, they should be very close. if not one is bad.
try thinner oil.
Nov 19, 2008 at 9:48 PM
