1994 Mazda Protege won't start
SHEKA3434
  • 1994 MAZDA PROTEGE
Engine Mechanical problem
1994 Mazda Protege 4 cyl Two Wheel Drive Automatic
i have a 94 protege and it wont turn over even though it sounds like it wants to. I replaced the spark wires, distributor, and fuel pump
Wednesday, September 23rd, 2009 AT 11:47 AM
Its cranking over and no start-Do below
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Wednesday, September 23rd, 2009 AT 1:24 PM
