sometimes the car will not turn off, you can turn the key to off, and the car stays running, now it will not start
May 12, 2008 at 8:25 AM
BMRFIXIT
✓Experienced Mechanic
check ignition switch
check battery and make sure its fully charged
if key out of ignition and dash light is on then you have a bad ignition or a feed back into the ignition system check if you had done any wiring
