1994 Mazda Protege Replacing a Blown Head Gasket
146,000 MILES • 4 CYL • FWD • AUTOMATIC
JERRYGOFF
Blowing white smoke. Temperature gauge is on high. No power. Smoke coming off of plug holes.
Car has no rust and everything works. Just had left front axle and muffler replaced. Paid $1200 for car about six months ago. Is is worth replacing the head gasket? Concerned that coolant has mixed with oil. Told by some mechanics that the bearings are shot even if the head gasket is replaced.
Don't have a lot of mechanical experience, but would be willing to try and remove head, have it repaired, and put back on. Need DETAILED, STEP-BY-STEP instructions for removing the head. What kind of tools will be needed? Also recommendations on what should be replaced such as head bolts, etc.
Oct 29, 2008 at 10:46 AM
JNOVACK
  • 723 POSTS
when you pull the dipstick is the oil look like chocolate milk and is this a single over head cam or a dual over head cam i can send you the instuctions on how to do the job but I need to know weather it is single or dual
Oct 29, 2008 at 12:10 PM
JERRYGOFF
Thanks for your response, Mr. Novack. I pulled the cap off of the valve cover and it has a chocolate milky substance on it. The engine is a 1.8cc, SOHC.
Again I'm not a mechanic so I need step-by-step instructions for removing the head.
Thanks,
Jerry Goff
Oct 30, 2008 at 2:50 AM
JNOVACK
  • 723 POSTS
here is the removal and install for your engine the figures at bottom are the timing diagrams to set the timing REMOVAL & INSTALLATION See Figure 1 CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
https://images.2carpros.com/forum/automotive_pictures/52960_0900c15280039788_1.jpg
Fig. 1: Cylinder head bolt tightening sequence for all 4-cylinder engines Before installing the cylinder head, thoroughly clean and inspect it, especially if the head needed to be removed to replace a blown gasket. Refer to the Engine Reconditioning procedures, later in this section. 1990-94 1.6L and 1.8L (except K8) Engines See Figure 4 Disconnect the negative battery cable and remove the engine undercover. Remove the air ducts from the air cleaner and throttle body. Tag and disconnect the spark plug wires from the spark plugs. Remove the spark plugs and the distributor cap and wires assembly. Remove the distributor. Drain the cooling system and disconnect the radiator and heater hoses.
https://images.2carpros.com/forum/automotive_pictures/52960_0900c1528003978b_1.jpg
Fig. 4: Exploded view of the cylinder head assembly for the 1990-94 1.6L and 1.8L (except K8) SOHC engines Disconnect the exhaust pipe and remove the exhaust manifold. On DOHC engines, remove the coolant bypass pipe. Disconnect the accelerator cable. Label and disconnect all necessary electrical connections and vacuum hoses. Disconnect the fuel lines. Remove the intake manifold bracket and the intake manifold. Remove the cylinder head cover bolts and the cylinder head cover. Remove the timing belt cover(s). Rotate the crankshaft, in the normal direction of rotation, until the No. 1 cylinder piston is at TDC on the compression stroke. Make sure the timing marks on the crankshaft and camshaft sprocket(s) are properly aligned and mark the direction of rotation of the belt. Loosen the timing belt tensioner and remove the belt. Do not rotate the crankshaft until the timing belt is reinstalled. When everything is disconnected, loosen the cylinder head bolts in the reverse of the tightening sequence. Remove the bolts and lift the head off the engine. To install: Thoroughly, clean the cylinder head and the block contact surfaces. Examine the head gasket and check the cylinder head for cracks. Check the cylinder head for warpage using a feeler gauge and straightedge. The maximum allowable distortion is 0.004 in. (0.10mm) on 1.8L engine. Clean the cylinder head bolts and the threads in the block. Make sure the bolts turn freely in the block. Install a new head gasket on the engine block. Make sure the camshaft sprocket timing marks are still aligned, as set during the removal procedure. Install the cylinder head. Lubricate the bolt threads and seat surfaces with clean engine oil and install them. Torque the bolts in 2-3 steps to 56-60 ft. lbs. (75-81 Nm) in the proper sequence. Make sure the crankshaft and camshaft sprocket timing marks are aligned, install the timing belt and set the tension. Carefully rotate the crankshaft 2 turns to make sure the timing marks still line up. Apply a thin bead of sealant to the cylinder head cover and install the new gasket. Install the cover and torque the cover bolts to 78 inch lbs. (9 Nm). Install the timing belt cover(s) and tighten the bolts to 95 inch lbs. (11 Nm). Use new gaskets and install the manifolds. Torque the intake manifold bolts/nuts to 19 ft. lbs. (25 Nm) and install the intake manifold bracket. Torque the exhaust manifold nuts to 34 ft. lbs. (46 Nm). Use a new gasket to connect the exhaust pipe and torque the nuts to 34 ft. lbs. (46 Nm). If removed, install the radiator and connect all cooling system hoses. On DOHC engines, install the coolant bypass pipe. Install the distributor, spark plugs, distributor cap and wires. Connect all vacuum and fuel system hoses and connect all wiring. Connect the accelerator cable and install the air ducts and engine undercover. Connect the negative battery cable. Fill and bleed the cooling system. Change the engine oil. Start the engine and bring to normal operating temperature. Check for leaks. Check the ignition timing and idle speed.
https://images.2carpros.com/forum/automotive_pictures/52960_0900c152800397c7_2.jpg
https://images.2carpros.com/forum/automotive_pictures/52960_0900c152800397c8_2.jpg
https://images.2carpros.com/forum/automotive_pictures/52960_0900c152800397c9_2.jpg
https://images.2carpros.com/forum/automotive_pictures/52960_0900c152800397ca_2.jpg
https://images.2carpros.com/forum/automotive_pictures/52960_0900c152800397cb_3.jpg
Oct 30, 2008 at 1:38 PM
JERRYGOFF
Hello Mr. Novack,
I have received your instructions. Thanks very much. I'm going to give it a try.
Regards,
Jerry
Oct 31, 2008 at 5:25 AM
JNOVACK
  • 723 POSTS
you have anymore questions feel free to ask I'm here to help
Nov 2, 2008 at 11:09 PM
