1994 Mazda Protege brakes freeze upl
89,000 MILES • 4 CYL • FWD • AUTOMATIC
DICKSNAZ
my son bought this car recently. after 15 minutes of driving brakes froze up and were smoking hot.car was towed and front pads,calipers and lines changed. rear
ebrake cable changed, rear drums and shoes checked.
same thing, when brakes begin to heat up engine works harder until brakes freeze.after an hour or so brakes cool and release. also when brakes are cool, pedal goes down about half way, as brakes become hotter, pedal becomes stiffer to push. 2 different mechanics have checked car and both have no other suggestions.
Nov 19, 2008 at 2:03 AM
JAMES W.
  • 2,394 POSTS
Is it front brakes, rear brakes or both? Please advise
Nov 19, 2008 at 9:35 AM
DICKSNAZ
IT APPEARS THAT ALL 4 BRAKES FREEZE--SEEM THAT BRAKE FLUID HEATS UP,EXPANDS, AND WILL NOT RETURN TO MASTER CYLINDER. AFTER AN HOUR OR SO BRAKES RELAX AND CAR WILL MOVE.
Nov 20, 2008 at 6:48 AM
THIS IS MIKE
  • 686 POSTS
You will need to remove the master cylinder. The rod that acuates the the brake master cyclinder may need to be wound in so the brakes can return to normal
Nov 21, 2008 at 6:48 AM
