1993 Mazda Protege radio quit, fuse good
121,000 MILES • 4 CYL • 2WD • MANUAL
DMOGIE
The radio is dead, the fuse is ok. Where do I start checking? The turn signal return switch does not work either and the under hood lamp bulb is out. Any connection? Everything else is working properly.
Jun 25, 2010 at 11:19 AM
DAVE H
  • 13,383 POSTS
check flasher and or replace turn signal switch ,, replace underhood bulb ..check both radio fuses
https://images.2carpros.com/forum/automotive_pictures/266999_rad_4.jpg
Jul 18, 2010 at 1:34 PM
