1993 Mazda Protege leaking
108,000 MILES • 4 CYL • 2WD • AUTOMATIC
DJH
I notice a steady drip of what appears to be water from behind the pulley even when the engine is not running...not much hot air out of the heater...related problems?...need a water pump replacement?...how expensive is that?...think a flush and stop-leak is an option?...where is the petcock on the radiator?...any advice will be welcome...thanks
Sep 4, 2010 at 6:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
heater will not work properly with low coolant in system and a faulty cooling system part. most definitely seems like water pump is weaping the coolant which is a sign of failed water pump. remove bottom radiator hose to drain coolant. i would not recommend a stop leak quick fix product on a failed water pump..
Oct 13, 2010 at 5:18 PM
