1991 Mazda Protege i need help
173,834 MILES • 4 CYL • FWD • MANUAL
IDAHOROKS
a few days ago i was stuck on the free in a rain storm and go stuck goin through a huge puddle.( 4-7 inches) my car almost died while goin through it and now it runs terrible. it starts and idles ok at first but as soon as you start to drive and it warms up a bit it gets wierd. when you start to drive it bogs in first gear then its fine until you try to stop or idle.( pretty much any time you let off the gas) it starts to choke out and act like the engine is going to die and most the time it does. it starts right back up and goes ok while driving. most of the problems are when you stop. i have replaced the plugs, wires, rotor, and distributor cap. i dont know what else to try. please help if you can
Jul 26, 2008 at 9:36 PM
MERLIN2021
  • 17,250 POSTS
Check any and all connectors that may have got wet, unplug and dry them. Check air filter for moisture.
Jul 27, 2008 at 1:00 AM
