HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mazda
Protege
Engine
Idle Air Control
1990 Mazda Protege Idle air control
SHREXIE
MEMBER
1990 MAZDA PROTEGE
4 CYL
FWD
MANUAL
17,700 MILES
How do I check the idle air control? When I am coming to a stop or slowing down my car wants to die.
Thursday, July 15th, 2010 AT 6:18 PM
MECHANIC
Get a repair manual or you can download it from here find it and clean out and see what happens
For manual go here:
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Thursday, July 15th, 2010 AT 6:30 PM
Please
login
or
register
to post a reply.
Related Idle Air Control Content
1996 Mazda Protege Idle Air Control Valve Resistance
Can You Confirm Info From My Manual: Resistance Reading On Terminals In The Iac Valve Should Be Between 10.2 And 12.7? Mine Reads 8.8 (ohms...
Asked by
matt64
1 ANSWER
1996
MAZDA PROTEGE
VIDEO
Idle Air Control Clean
Instructional repair video
GUIDE
Idle Air Control Valve Service
The idle air control valve is responsible for controlling the engine idle speed via the car's PCM (computer). These valves are configured differently depending on...
I Come To Stop And It Seems To Want To Stall Out?
96 Mazda Protege, When Driving I Come To Stop And It Seems To Want To Stall Out, Or Just Idling And I Put It In Drive And It Seems To Be...
Asked by
kevind65
1 ANSWER
3 IMAGES
1996
MAZDA PROTEGE
Timing Belt?
My Car Jumped Timing. How Do I Reset It?
Asked by
teenie67
16 IMAGES
2003
MAZDA PROTEGE
Post Cat Oxygen Sensor
I Have Intermittent Check Engine Light P0420. I Checked The Voltage Of The Post Cat Oxygen Sensor It Was Fluctuating Between 0.420 To 0.435
Asked by
zemorzemor
2000
MAZDA PROTEGE
How Do I Find The Engine Block Drain Plug On My Mazda...
Engine Block Drain Plug Location On Mazda Protege Lx 1.6l
Asked by
dalene56
2000
MAZDA PROTEGE
VIEW MORE
Clean Idle Air Control Ford Super Duty 5.4L
Idle Low
