2001 Mazda Millenia Steering Vibration
MAZDA
GMESSY
I have a 2001 Mazda Millenia. It is a 2.3L V6 with approx 70000 miles on it. We are having problems with the steering in certain situations. When turning the steering wheel there is a repetitive vibration that occurs. It almost feels as though the something is slipping. After a few seconds it stops, but if I turn the wheel the other directin it will occur again for a few seconds. It only occurs when we are stopped or moving vey slowly (for instance when we are parallel parking. Any ideas?
Nov 16, 2007 at 8:22 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it could be a sticky rack and pinion. Try having the power steering system flushed out and fresh fluid put in. That doesnt fix it, might have to replace it
Nov 18, 2007 at 12:02 AM
Suggested Repair
Flush the power steering system and refill with fresh fluid. If the vibration continues, the rack and pinion may be sticking and may need replacement.
Conversation Summary
The owner of a 2001 Mazda Millenia with about 70,000 miles reports a repetitive vibration or slipping sensation when turning the steering wheel. It lasts a few seconds, returns when the wheel is turned the other way, and occurs only when stopped or moving very slowly, such as while parallel parking. The expert suggests a sticky rack and pinion and recommends flushing the power steering system and installing fresh fluid, with rack replacement if that does not fix it.
