2001 Mazda Tribute Oil Light Blinks
MAZDA
JGONZALEZ
Hello, I have a 2001 Mazda Tribute V6 ES, with 69,000 miles. After driving for a while on a full stop or if the car is in park the Oil light begins to blink, the mecanic told me it could be the oil pump, or the oil. since I bougth it used i decided it to chenge the oil pump. After changing the pump the same situation I cahnge the oil and put HD 40, the problem stopped on the last change of oil the problem started again.
What do i need to do?
thank you
Feb 13, 2007 at 6:13 AM
COSMO
  • 347 POSTS
The first question is.....have you been changing your oil every 8000km's? Sounds to me like you shold have you oil pressure tested
Cosmo...Mazda TEch
Feb 13, 2007 at 10:01 AM
JGONZALEZ
Yes I have had it checked the mecanic says it's ok, but when the ligth blinks he does see a small drop in presuure, that was why he recomend the oil pump change. What else could it be?
thank you for your help
Feb 14, 2007 at 1:37 AM
  • 75,988 POSTS
Could be excessive engine bearings clearance.
Apr 2, 2007 at 6:14 PM
Suggested Repair
Have oil pressure tested, especially while the light is blinking at a stop or in park. If pressure drops, inspect for excessive engine bearing clearance and confirm the correct oil viscosity and regular oil changes.
Conversation Summary
The owner of a 2001 Mazda Tribute says the oil light blinks after driving when the vehicle is stopped or in park. Replacing the oil pump and switching to HD 40 oil only temporarily helped. A mechanic reported a small pressure drop when the light blinks. Experts recommend confirming oil-change history and testing oil pressure, with excessive engine bearing clearance noted as a possible cause.
