1995 Mazda 121 Oil Light Flickering
MAZDA
TYLER38
I have a 1995 Mazda 121 and I have recently had trouble with the oil light flickering then staying on. I have oil in the engine and have recently changed that oil. I also get a "whirring" noise in my engione when it starts :?:
Jul 15, 2006 at 2:32 PM
MIKEYBDMAN
  • 623 POSTS
You need to find out if your engine is producing oil pressure, or if it is an indication problem. You can remove the pressure indicator sendor and install a direct reading gauge to see if you have oil pressure. Should have atleast 15-20 psi at idle even when the engine is warm. When it first starts, it should be around 40 psi, and as it warms up it will go lower. But never below 15 psi at idle, and should be around 40 psi with the engine rev'd up.
If you do see this pressure when you start, shut it off fast, and repair your oil pump. You can destroy the engine by running with low oil pressure.
If your oil pressure is fine, then you have an indication problem with probably a loose wire or bad connection.
Good luck
Jul 16, 2006 at 7:39 AM
Suggested Repair
Install a mechanical oil-pressure gauge in place of the sender. Expect about 40 psi at startup and at least 15-20 psi at warm idle, and about 40 psi when revved. If pressure is low, shut the engine off immediately and repair the oil pump to avoid engine damage. If pressure is normal, check for a loose wire, bad connection, or faulty oil-pressure sender.
Conversation Summary
The owner of a 1995 Mazda 121 reported an oil light that flickered and then stayed on despite a recent oil change and adequate oil, plus a whirring noise at startup. The expert advised verifying actual oil pressure with a direct-reading gauge rather than relying on the warning light. Low pressure requires an immediate shutdown and oil-pump repair; normal pressure points to a wiring or sender indication problem.
