Mazda6 with throttle problems
MAZDA
DAN331
My wife's 2003 Mazda6 has 120k miles on it. She told me that while she was driving down the interstate it lost power slowing the car down pretty fast. She pulled to the side, cut it off, and then restarted it without any problem. She also said it feels like the car tries to keep going when she is stopping sometimes.
It has a cel on so i checked that and it read a bad throttle position sensor. (P2135 TP sensor No.1/No.2 voltage correlation ON 1 CCM)
99.9% of the time the car runs fine. I checked with mazda and the sensor is only sold with the whole throttle body, which pushes the fix out of budget, especially when it's only a maybe. Is there anything else this could be or does it sound like it is a TPS?
Thanks,
Dan
Sep 26, 2007 at 9:17 AM
COSMO
  • 347 POSTS
The throttle plate incorperates:
Throttle control
Cruise control
Idle Speed
The code you are getting is for the fact that one of the two sensors in the throttle body has gone out of range on more than one occasion. There is NO way to replace just one of the sensors. The throttle body comes as one piece. This is more than likely the problem, it is not uncommon for the throttle bodies to fail. If you have a complete failure of the TB, you will lose all but (around) 15% throittle opening (enough to move the car).
I don;t recommend used parts in this case
Cosmo
Mazda Tech
Sep 27, 2007 at 4:04 PM
TREVAN
I have a 2003 Mazda 6 with just over 80,000 miles on it and the throttle sensor is apparently bad. I have just been informed that the part I ordered on Dec. 21, 2010 is now Estimated to be at a distribution center on Feb. 2, 2011!! That means over a month with no car. I am thinking of resorting to a junk yard search. Is that crazy? I have to go to work and make a living. Horrible, horrible customer service on Mazda's part. Very disappointing.
Jan 6, 2011 at 2:31 PM
