I put tha positive cable on the negative side and the negative on the positive side at the batery, now the car wont start, what can be the problem?
i fix the cables and check fuses aready.
Sunday, June 17th, 2007 AT 9:27 PM
REYNOLDS810
MEMBER
Does it turn over and not start or does it do nothing at all when you try to start it?
SPONSORED LINKS
Sunday, June 17th, 2007 AT 10:19 PM
ROBERT DOIG
MEMBER
1 POST
The indicator on the right hand side of my car is
stuck on, I cant get it to go off so I have had to disconnect the indicators. They arnt flashing they are just on. Would this be a fuse problem maybe?
