converter
MAZDA
THERESA LEE
I had my cadalic converter replace last year and I believe that is has stop up on me again. Instead of replacing it again can I just have them removed. :cry:
Feb 14, 2006 at 11:20 PM
KARENCAREN
  • 72 POSTS
No. That converter is important to your car. If you remove it you will have another problem which I think will be more serious than replacing that converter.
Mar 2, 2009 at 12:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You can remove it but this will cause poor fuel mileage and will also fail emissions test if your state requires them. Otherwise, you can remove it.
Mar 2, 2009 at 12:21 PM
Discussion summary
converter
The poster says they had a catalytic converter replaced last year and now believes it has clogged again; they ask whether it can be removed instead of replaced. This is the poster's account of a recurring converter issue with no vehicle details, symptoms, or diagnostic tests given.
Reported outcome: No resolution or follow-up result was reported by the poster in the thread.
Read the original discussion
