98 millenia, 2.5 v6, 150,000+ miles
1998 MAZDA
DLUBALAMADISON
Timing pulley broke while running, got it home (about 1 mile drive). Replaced timing belt and pulleys, harmonic balancer, intake gaskets, valve cover gaskets, plugs and wires, fuel filter, distributer cap & rotor button, new water pump, new ac & alternator belts (most of these weren't a problem but replaced them while we had everything apart). Got it all back together and now the car won't start. Tore it back down to the cams 3 times to check all the alignments, everything plugged in etc. Has TDC. Still won't start. Any suggestions appreciated!
Aug 4, 2007 at 5:40 AM
SYSLIPIE
as dumb as this sounds i did the same thing only in a 93 when i parked it it ran after it was all back together it wouldnt start. do your self a favor and check the fuel pump fuse
Nov 28, 2007 at 8:43 AM
