2004 Other Mazda Models Can't fill with gas!
2004 MAZDA
50,000 MILES • 4 CYL • 2WD • AUTOMATIC
MIWLOD
My tank takes forever to fill with gas and the dealer says there is a valve in the tank that can't be serviced or replaced and the whole tank has to be replaced because of it! Can this be true?
Jan 9, 2008 at 12:16 AM
BLACKOP555
  • 10,386 POSTS
hes right, but first check your fuel fill hose and make sure it is not kinked, then find the vaccum line on the tank and follow it up to the charcoal canister checking for cracks or cuts, if that is all good, test the canister if thats good then you will have to have the new tank.
Jan 9, 2008 at 12:26 AM
