2002 Other Mazda Models ABS light is on
2002 MAZDA
92,000 MILES • 6 CYL • FWD • AUTOMATIC
ABOUTCARS02
Hi guys, i have a 02 mazda millenia 2.5 V6. My problem on my car is when my car hit 85 miles per hour the ABS turns on but my brakes are working fine in all that..then the next day the ABS indecator will disappear..But before that ABS came on i replaced my cv joint it was my rf axle..then a week later i was in the highway i reach up to 85 miles per hour the ABS light indecator came out and that was the first time i saw it..let me know what you guys think is the problem...thanx..you guys rock!!!
Mar 11, 2008 at 1:04 PM
MASTERTECHTIM
  • 4,750 POSTS
check the new axle. see if the reluctor ring on it(if it has one) sometimes if there is a crack in the ring where it goes around the axle it will throw off the wheel speed sensor. also make sure the air gap on the speed sensor did not get messed up when changing the axle.
Mar 11, 2008 at 1:14 PM
