1995 Other Mazda Models cut off
1995 MAZDA
PATRICIA PRUNTY
Electrical problem
1995 Other Mazda Models 4 cyl Two Wheel Drive Automatic 100.00 miles
My car cuts off when I'm driving it ,the last time it cut off I could not get it to start up, had anothr motor put in but now it turns over but it won't start up.
Jun 6, 2010 at 11:51 PM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 6, 2010 at 11:58 PM
