1994 Other Mazda Models WHITE SMOKE
1994 MAZDA
SWEETROSE69
Smells problem
1994 Other Mazda Models 4 cyl Two Wheel Drive Manual
1994 MAZDA MX-3
I JUST GOT THIS CAR FROM A PARENT AND IT HAD BEEN SITTING FOR 2 YEARS. AFTER SOME WORK ON THE BRAKES AND MUFFLER I WAS ABLE TO GET IT ON THE ROAD. WHEN I FIRST GOT IT RUNNING THERE WAS THIS WHITE SMOKE COMING OUT OF THE EXHAUST SO I FILLED IT UP WITH 93 OCTANE GAS AND PUT DRY GAS IN THE GAS TANK AND SOME STUFF CALLED SEA FOAM IN THE GAS TANK AND THE OIL. I WAS TOLD THAT THIS WHITE SMOKE THAT WAS COMING OUT OF THE EXHAUST WAS WATER IN THE GAS TANK FROM IT SITTING FOR SO LONG. I HAVE FILLED IT UP TWICE NOW AND DROVE IT FOR 250 MILES.THE WHITE SMOKE ONLY COMES OUT WHEN I FIRST START THE CAR FOR ABOUT 5 MINUTES TILL IT WARMS UP, FOR THE REST OF THE DAY THERE IS NO SIGN OF THE WHITE SMOKE. I AM NOT LOSING ANY ANTIFREEZE. BEFORE I TAKE IT TO GET ANOTHER OPINION I THOUGHT I WOULD ASK YOU. COULD IT BE TRUE THAT IT COULD BE WATER IN THE GAS OR IS IT SOMETHING ELSE.
Apr 14, 2008 at 11:38 AM
SERVICE WRITER
  • 9,123 POSTS
Seafoam will smoke. May have started out as moisture from setting, but run a few tanks of gas through it until the seafoam is gone.
I Like seafoam and use on intake cleaning. IF too much is in there too quick, You can create a heck of a smoke screen.
Apr 14, 2008 at 11:43 AM
