1993 Other Mazda Models Engine misses
1993 MAZDA
73,000 MILES • 4 CYL • 2WD • MANUAL
RICKMCALLISTER
This just started. I noticed that the engine misses and idles rough. Alos I noticed that there is a tapping noise coming from the engine. All the plug wires are connected and I didn't see any leaking sparks.
Jan 3, 2008 at 4:37 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
You may want to run the engine on an oscilloscope, this will give a true indication as to the viability of the ignition system, You wont always see a spark earthing, nut what you describe does sound like it, you could just change the plugs, leads, & filters, but the scope will show coil voltages & ignition pattens as well as identify any earth leakage, a good mechanic will diagnose any basic problem on a scope in under 5 min.
Mark (mhpautos)
Jan 3, 2008 at 12:47 PM
