1992 Other Mazda Models cooling
1992 MAZDA
920,000 MILES • 6 CYL • 4WD • MANUAL
DEANSMITH06
I live in alaska and my cooling is not working it heats up I have put a new cap and thermostat, water pump seems to work the coolent seems to end up in the resavor had worked fie all summer
Nov 2, 2008 at 7:31 AM
  • 75,988 POSTS
Are you overheating? my cooling is not working it heats up-explain what you meant by this-don't quite get it-
Nov 2, 2008 at 8:35 AM
DEANSMITH06
[quote:4daead3f8f="rasmataz"]Are you overheating? my cooling is not working it heats up-explain what you meant by this-don't quite get it-[/quote:4daead3f8f]
THE gauge reads hot im sure it is as I have to add fluid and my res is full after I add it gose down and the heater will work could this be a head
Nov 2, 2008 at 8:52 AM
  • 75,988 POSTS
Could be air lock in the cooling system-get it bleed and see what happens-if it continues get it block and pressure tested to ID a blown headgasket/cracked head or block.
Nov 2, 2008 at 9:02 AM
