1996 Mazda MX6 Oil leak
135,000 MILES • 4 CYL • 2WD • MANUAL
MINNOWMOUSE
As I drove home this evening I smelled oil burning, no lights came on and car was not overheating. I opened the hood of my car and it was smoking. I checked water levels and oil level - everything was fine. I went out to check again about 1/2 hour later and started the car to check it for overheating.
Then I looked under my car and there was about 1/4 cup of oil that had poured out of my car. I moved it to the street and it left a small streak of leakage along the driveway. I checked it again about an hour later and there was just a small pool of oil under the car. I didn't check oil level again because it was dark outside.
What do you think it could be? When I looked closely at the engine, it looked like oil was spilled up high in the engine, about same level as oil filter - but not coming from oil filter.
Jun 17, 2008 at 1:39 PM
  • 31,937 POSTS
Hi there,
Check the oil pressure switch, as these are often the cause of this excessive oil leak, i will try and post a pic of it's location soon.
mark (mhpautos)
Jun 17, 2008 at 3:06 PM
MINNOWMOUSE
Thanks for your reply; I'll look in my manual but don't think it has that much info. I'll wait for you to post picture today if possible!
Jun 17, 2008 at 10:43 PM
