1996 Mazda MX6 MX6 Shudders whilst accelerating
1996 MAZDA MX6
174,000 MILES • 6 CYL • FWD • AUTOMATIC
REDDOGS8
Hi There. My Mazda MX6 just started shuddering / shaking when accelerating from 1st gear. The RPMs drop and the more I push the accelerator, the more it shudders and the slower it goes. I can have the gas pushed all the way to the floor and the car wont go over 40 km/h. When ideling, the exhausts sounds like its blowing bubbles (put-puting).
Jul 12, 2010 at 9:09 PM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below:
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 13, 2010 at 11:46 AM
