1993 Mazda MX6 starting
140,000 MILES • 6 CYL • FWD • MANUAL
PROJECTCAMARO
car will start but stop have replaced cam sensor, crank sensor, fuel filter, fuel pump, injectors, idle position sensor, timing belt and have had professional mechanic time car and install belt and still wont stay running just starts and stops
Feb 11, 2010 at 9:12 AM
  • 75,988 POSTS
If it has the correct fuel pressure -try cleaning out the idle air control valve, EGR valve and test the throttle position sensor and airflow meter
Feb 11, 2010 at 10:34 AM
