1993 Mazda MX6 my car shuts off while driving
1993 MAZDA MX6
145,000 MILES • 4 CYL • 2WD • AUTOMATIC
ELIJAHANDMALACHI
when im driving i loose all power my accelerator doesnt do anything no power at all my car shuts off to and when i go to start the car it turns over but isnt catching why?
Jul 21, 2010 at 1:30 PM
Check what's missing do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jul 21, 2010 at 1:44 PM
