mazda 93 mx6 2.0 120,000 shuts down after 5-10 mins
FEAR30X
  • 6 POSTS
After 5-10 mins engine shuts down then you get no spark at all...Check engine lights does NOT come on, car is NOT overheating and the cooling fans are working...Car starts back up after approximately 20 minutes as if there is not a problem...Before all this started the car had a broken spark plug wire which has been fixed, then drove vechile for approximately 2 miles and problems started over...New distributor New spark plug wires was installed last year..and plugs installed this week
I think the problem is possibly the ignition module
Any helpful suggestions are appreciated
Mar 25, 2007 at 8:08 AM
FEAR30X
  • 6 POSTS
update :
now i did get a few codes out of it code 17, 25, 28 .. the 17 was removed after i disconnected the neg terminal..
so all i have now is code 25 , 28 one if fuel sensor, other egr sensor
Mar 27, 2007 at 2:11 PM
FEAR30X
  • 6 POSTS
i ran ( idle) car yesterday 45 mins with no problem..no shut down or nothing, road tested with no shut off or anything. i guess the funky mazda cat n mouse tricks.. now you see me now you dont which is what i went thru with the dist. be4 it was replaced.. i am heading out to check and clear codes and hope not to be roadside
https://images.2carpros.com/forum/automotive_pictures/65873_468619317418147371_1.gif
Mar 29, 2007 at 2:09 AM
FEAR30X
  • 6 POSTS
DAMN CAR CRAPPED out again with no spark again, aint life grand
Apr 1, 2007 at 11:02 AM
DPAISLEY
I don't know if this may or may not be you problem, but I had the same issue with my Mazda pickup and troubleshooted the heck out of it to find out it was the computer going bad. If its one of the models that Mazda made, its sure to go out. I found several websites that explained it better than I am, now. Basically, Mazda used some cheap capacitors in them that would slowly bleed out onto other computer components on the board, making all kinds of wierd issues, depending on what it damaged...check it out visually and see if you can see any burned or melted parts on it and its sure to be you problem...hope this helps...
Jun 9, 2008 at 8:19 AM
