ignition problem
MAZDA MX5
CANDIHADDOCK
Hi. My son stuck a stick that broke in the ignition switch. The ignition key will not go all the way in know. Any suggestions? 1991 mazda mx6
Mar 26, 2006 at 7:13 PM
T_BROCK
  • 7 POSTS
You know the tools dentists use to scrape the tarter off your teeth. They're thin and long and curve with a pointed end. If you can find one of these tools (maybe call your dentist), you might be able to reach into the lock with this tool and pull out the pieces of wood.
Apr 4, 2007 at 3:01 PM
