Mazda MX6 Cranks But Won't Start
DANNYBOBLITT
I was driving home from work when my car just stopped running. Will not start. I changed the fuel pump but that didnt fix the problem. The car turns over but will not start.
It is a five speed, 159000 miles,mx6 w turbo
ok!, I changed the fuel pump, spark plugs & wires, dist cap, rotor, and fuel filter.
I check to see if I was getting fuel through the filter-no fuel. I check to see if I had any spark-no spark.
Where do I go now? No spark No Fuel-what controls these two. The car turns over and that is about it.
took car to the repair garage. They checked it out and told me the distributor was bad. I went and bought a distributor. They put it on yesterday. I called them today to see if car was ready. They told me that it didnt fix the problem.They are now telling me the computer is bad. This the conclusion I came to when I took it into them. What do you think.
It is a 2.2l I think
Oct 24, 2007 at 4:26 PM
  • 75,988 POSTS
Check the main relay and ignition fuse-if okay pull a plug wire and ground it while cranking it over-do you have spark?
Oct 24, 2007 at 4:39 PM
  • 75,988 POSTS
[quote:f3f7b3d5e7="dannyboblitt"]I was driving home from work when my car just stopped running. Will not start. I changed the fuel pump but that didnt fix the problem. The car turns over but will not start.
Where do I go now? No spark No Fuel-what controls these two. The car turns over and that is about it.[/quote:f3f7b3d5e7]
What is it a 2.0 or 2.5 liter?/ year
You will get an injector pulses w/o spark am having the same problem its only been 2 mos. with a 2.5 w/auto
Okay look for the crankshaft position sensor at the crank. Test its resistances with an ohmmeter should read 520 to 580 ohms do this 1st.
Oct 27, 2007 at 2:48 PM
Suggested Repair
Check the main relay and ignition fuse, then confirm spark at a plug wire while cranking. Also test the crankshaft position sensor resistance (about 520-580 ohms) before replacing the computer.
Conversation Summary
A Mazda MX6 turbo died while driving and now cranks but will not start, with no spark and no fuel. The owner replaced the fuel pump, plugs, wires, distributor cap and rotor, fuel filter, and distributor, and the shop then suspected the computer. Experts advised checking the main relay and ignition fuse, verifying spark, and testing the crankshaft position sensor.
