'92 Mazda MX3 V6 5-speed 206,000 miles
IMJIMSMITH
  • 13 POSTS
Multiple issues with a fairly new car. I'll start with a little history: One owner for first 200,000 miles (kept and transferred a complete record of maintenance) who gave car to his son in perfect condition. It was driven for about 5500 miles and got in a front end mostly cosmetic accident. I bought it 5 months later (it may have been started once during that time) and it ran for 2 months. During this time, the 'charge batt' light would be on when I started the car and go off after 10-20 minutes. It would still come on at high RPM's (above 4k) even after running for 2 hours. I had it checked at the local parts store and both battery and alternator checked out good. Near the end of this two month period, the car started stalling after putting clutch in usually after coming off the highway. The frequency increased to the point that it would stall at most stops. Tack reads 500rpm , engine sputters, rpm's drop, it catches, goes up to 1000 then back to 500. It would eventually stall out if I dont give it some gas. This was not too bothersome until it stalled and would not restart on Saturday.
Earlier on Saturday I had it in to a reputable oil change shop. There is no release for the hood inside the car but I didnt get out to tell the techs until they had already disconnected a ground cable that connected to my fuse box under the dash (I found the wire on Sunday). It was that night, roughly 60 minutes total travel time when the car quit starting. it acted like I had blown a fuse on stopping (lights went out, radio died, presets reset). I took the key out and put it back in. Lights and radio came back, but not enough juice to start. The next day I checked all fuses inside and under the hood; all good. I jumped it and it started right up. I drove it to my house, let it idle for 20 minutes, drove it on a short trip to get the other car and it stalled on the way back. Battery wouldnt start the car and I jumped it again.
I took the car to the parts store again and they informed me after applying a load and the battery dropped to 1.2 volts that my battery was shot. I bought a new battery, installed it, and tried to start the car; no dice. I jumped the new battery and it started back up. Drove it, stalled, wouldnt restart. Took it back the the lube shop, had them reattach the ground wire, let it idle, tried to start, still not enough juice. Jumped it and it runs till it stalls, which is at every stop now.
So my question is two part:
1.) What is causing the stalling?
2.) Why wont the battery charge?
Other notes, I have read many of the questions and it appears it may be an issue with an Idle Air Control or an Idle Speed Motor. Where should I look for that? I was told by two people to start the engine and disconnect the positive batter terminal, which I did (not having read the many answers that said not to do this) and the car didnt stall. I have a multimeter and will check the voltage across the terminals, but if that checks out, what other cause could there be for the battery not charging?
I'm a novice at this but trying to save some money by doing the work myself. If anyone has information or an idea on where to start, I would appreciate the help.
Jan 2, 2006 at 1:05 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Use the documented repair history if the symptoms recur. Have loaded cable checks and an idle-system assessment performed rather than repeating parts replacement. Do not disconnect a battery cable while the engine is running as a charging test.
Guidance references and applicability
Source: This question and its visible discussion. The roadmap distinguishes the original owner's reports from other participants' experiences; proposed follow-up is editorial guidance, not a confirmed diagnosis. Fluke: Diagnosing voltage drops https://www.fluke.com/en/learn/blog/automotive/electrical-automotive-troubleshooting General support for loaded circuit testing; use matching vehicle specifications.
Read the replies · Discussion summary and reported outcome
IMJIMSMITH
  • 13 POSTS
I checked a few things out today after reading some of the answers elsewhere on the site. I checked the alternator the correct way, multimeter on the battery terminals, and I get a solid 14.5v (up from 12.6 when off). That tells me it is working. I turned on the headlights, A/C, and radio, and the voltage fluctuated breifly by as much as .5v, but went back to 14.5v almost immediately. I let it run for 10-15 minutes and it didnt have enough to start up (new battery). Any ideas on why the battery does not appear to be charging?
I also checked the distributer cap for the stalling issue. It definately had some corrosion on the contacts and the brush (correct words?). I cleaned them pretty well with a contact cleaner I have and put it back together. Stalling continues when coming down from anything above 1000 RPM's. I guess the next step is to check the Idle Control Motor. Any way to test that short of replacing it and seeing if that works?
Someone had mentioned I check the cylinoid (sp) for the starting issue but I cant find the starter, nevermind the cylinoid. But from what he said about the cylinoid though, it shouldnt start my car at all if it is out, but it starts fine if I jump it.
I think I am going to try and find a Haynes today to continue working this out. Any advice would be appreciated.
Jan 3, 2006 at 3:01 AM
IMJIMSMITH
  • 13 POSTS
I gave up and took it to the shop.
Battery not charging: Bad ground wire off battery. Replaced - battery charging.
Stalling: Air Conrol Motor boot, distributor cap, spark plugs and cables - all replaced.
Total: $350
They had the problems figured out in 25 minutes, I spent three days under the hood. I suppose thats why they get $80/hour for labor.
Jan 5, 2006 at 8:25 AM
IMJIMSMITH
  • 13 POSTS
$460
Seems like it keeps going up. It runs great tho!
Jan 9, 2006 at 9:09 AM
Discussion summary
A 1992 Mazda MX3 developed charging warnings, repeated stalling and starting trouble. A replacement battery did not resolve it. The owner eventually reported that a shop replaced a bad battery ground wire and an idle-air-control boot, distributor cap, plugs and leads.
Reported outcome: The owner reported restored charging after the ground-wire replacement and said the car ran well after the shop repairs.
Several parts were changed together, so the thread does not isolate one cause of stalling. The historical bill is not a current estimate.
Read the original discussion
