2000 Mazda MX5 Engine will not turn over
2000 MAZDA MX5
39,000 MILES • 4 CYL • 2WD • MANUAL
JUMPSTARTER
I have a brand new battery that worked two months ago. The car has not been turn on for two months now. I tried to start the car and it would not turn over. No check engine lights, nothing. I have a battery charger and plugged that in and it showed the batter as being fully charged. The security light does show on the dash, but that is the only thing showing power.
Absolutely nothing happens when I put my key in the ignition and turn the key...no sounds what so ever and no lights showing power.
Any suggestions?
Feb 1, 2009 at 6:53 AM
RICH CRITES
  • 75 POSTS
Did you check the starter magnetic switch? You may also have a bad starter. It could also be the ignition switch.
Mar 31, 2009 at 5:52 AM
