1995 Mazda MX-3 Front Sits Too High
PARKY
'95 MX-3 Precidia, 1.6 Litre 5spd. 127,000Km
A "friend" of mine recently replaced the front coils and struts on this car. The front of the car now sits about 5 inches higher than it should. Is it more likely that the strut is too long or could it be the coil spring that's causing this issue?? Unfortunately he no longer has the part numbers of the items he installed.
Help!!
Parky
Apr 21, 2006 at 1:12 AM
LOSONE
  • 1,616 POSTS
You have the wrong struts or springs. You will have to buy the right ones and have them installed. It sounds like the mechanic didn't know his spring from a strut.
Apr 21, 2006 at 5:23 AM
Suggested Repair
Replace the front struts and coil springs with the correct parts for this vehicle and have them installed properly.
Conversation Summary
The owner reports that the front of a 1995 Mazda MX-3 sits about 5 inches too high after a friend replaced the front coils and struts, and the part numbers are unknown. The expert says the wrong struts or springs were installed and that the correct parts must be purchased and installed.
