1991 Mazda MX5 over heating
151,000 MILES • 4 CYL • 2WD • AUTOMATIC
KASEY123
my ignition is kinda messed up and i will start my car and it starts to over heat after a while but my dad said you have to get hte ignition in the right spot and i wanted to know what else it could be and nothing is leaking no fuses are blown i have anti freeze and all the right fluids at the right levels so what else could it be.
Apr 23, 2009 at 12:47 AM
  • 75,988 POSTS
Check the thermostat for a start
Apr 23, 2009 at 12:51 AM
KASEY123
its not that its the ignition its so messed up that the fans dont come on the fans are working i tried it yesterday my dad said to get the ignition in the right spot but i was wondering if there could be something else causeing it to overheat
Apr 23, 2009 at 1:07 AM
  • 75,988 POSTS
Square away the ignition switch and then find out what's causing the fans not to come On-could be the relay/coolant temperature sensor/temperature gauge switch/computer
Apr 23, 2009 at 1:37 AM
