1991 Mazda MX5 i think idle is low
103,000 MILES • 4 CYL • 2WD • MANUAL
CMBAYE01
  • 8 POSTS
when i start my car it starts fine and then it gose to about 250 rpms, and the engine almost dies, then it gose back up to about 800 rpms, it will not idle higher. if i rev when in nuteral it goes up fine but then it goes back to about 200 rpms and almost dies. i changed the spark plug wires, and if i feel one of them above the spark plug i can feel it ticking, the others dont do that, and i can hear that one ticking farly loud. if i replace the spark plug do you think it will fix my idle problem? or do most manual cars do that?
thanks chris.
Jun 5, 2009 at 8:50 AM
  • 75,988 POSTS
That could be causing the imbalance of power. Also check the idle speed control and throttle position sensor to include the EGR and PCV valves
Jun 5, 2009 at 9:13 AM
CMBAYE01
  • 8 POSTS
i took the spark plug out and it was just loose, i tighted it and it does not tick any more, but it still idles low,
Jun 6, 2009 at 2:55 AM
