1990 Mazda MX5 Lack of power
120 MILES • 4 CYL • 2WD • AUTOMATIC
FROMSA
When driving no power.
Oct 18, 2010 at 3:09 PM
  • 75,988 POSTS
Check the exhaust system for restriction could be a catalytic converter and igniton coil -see below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 18, 2010 at 6:43 PM
