1995 Mazda MX3 subframe
SEBASTIEN00
Suspension problem
1995 Mazda MX3 Front Wheel Drive Manual
i was offered an mx3 by a friend but it is rusting badly on the subframe would i be able to unbolt this from this car as some other models and put a new one on if so how big a job would this be
Jun 1, 2009 at 1:22 PM
BILLYMAC
  • 2,204 POSTS
Hi, Yes you certainly can,if you are talking about about the front section and not the rear. the front is easier then the rear.and as far as changeing it. you have to be very cautious everything bolted to the subframe has to be supported bye a chain or suitable tool. it just depends how much labor you want to put in this project.. in answer to your question yes it can be done. billymac
Jun 1, 2009 at 1:32 PM
