1995 Mazda MX3 alinement of crankshaft
215,000 MILES • 4 CYL • 2WD • MANUAL
HOMIECHIC
  • 5 POSTS
Where are the cam gear marks suppose to be and what do they look like? ( to replace the timing belt). The waterpump was changed and the cam gears were marked before the belt was removed, but after reassembly and starting the motor the timing (idle) was off. Now everything is back together and the marks (the ones we did) can't be found and there seems to be 3 stamped marks (on the front of the cam gears) and i'm unsure of which ones to use, and as to what location these should be.
Help, it's turing out to be a 3 day project.
Thanks
Aug 30, 2008 at 2:32 PM
  • 31,937 POSTS
Hi there, Cam timing marks as per pic. Mark (mhpautos)
https://images.2carpros.com/forum/automotive_pictures/61395_Graphic_46.jpg
If you require more info please re post.
Aug 30, 2008 at 4:18 PM
