my mazda runs fine but when i press the gas it smokes crazy and it smells like gas not oil what could be the problem and solution
Sep 29, 2010 at 2:09 AM
✓Experienced Mechanic
Hi jason tate, Welcome to 2carpros and TY for the donation
Sounds like its running too rich could be caused by the following below
1.Excessive fuel pressure can be cause by restricted fuel return line or defective fuel pressure regulator.
2.Defective Oxygen Sensors.
3.Leaking injectors and fuel pressure regulator.
4.Coolant temperature sensor out of calibration.
5.Restricted air intake system.
Sep 29, 2010 at 2:30 AM
GEORGEESTREMERA
MEMBER
1 POST
So how do you fix the above problems, especially #2?
