1993 Mazda MX3 Idle surges when in in gear
KWHITLER
Engine Performance problem
1993 Mazda MX3 6 cyl Two Wheel Drive Manual
Idle is high (1500 rpm) when in neutural and pulses between 1000 rpm and 1500 rpm when in gear.
Oct 12, 2010 at 12:03 PM
  • 75,988 POSTS
Inspect and test the idle air control valve, EGR valve, airflow meter and throttle position sensor-also look vacuum leak
Oct 12, 2010 at 3:18 PM
