1992 Mazda MX3 what can it be
1992 MAZDA MX3
BUSTERE.01
Noises problem
1992 Mazda MX3 6 cyl Front Wheel Drive Manual
New trann, new clutch...still makin winning noises in first, second, and reverse. have to let off the clutch a little to put in reverse. what do u think is making all the noise? please reply.
Thank you!
Mar 21, 2009 at 1:55 AM
MERLIN2021
  • 17,250 POSTS
Can be either of these problems. CLUTCH SQUEALING NOISE - REPLACE CLUTCH DISC TECHNICAL SERVICE BULLETIN Reference Number(s): CAAT. H, NO. 95-02,  Date of Issue:   May 1995 Related Ref Number(s): CAT. H, NO. 95-02 ARTICLE BEGINNING CLUTCH SQUEALING NOISE Models: 1990-93 Mazda 323/Protege 1994 Mazda 323 1992-94 Mazda MX-3 1994 Mazda Protege Category: H - Clutch Bulletin No.: 95-02 Date: May 1995 APPLICABLE MODELS/VINS/WITH MANUAL TRANSAXLES All 1992 MX-3 vehicles with a B6 engine and a VIN range of JM1BG23 ** R0700001 through JM1BG23 ** R0745862. All 1993 MX-3 vehicles with a K8 engine and a VIN range of JM1EC43 ** P0200001 through JM1EC43 ** P0230541. All 1994 MX-3 vehicles with a B6 engine and a VIN range of JM1EC43 ** R0300001 through JM1EC43 ** R0302013. All 1994 Protege vehicles with a BPSOHC engine and a VIN range of JM1BG **** R0700001 through JM1BG **** R0789348. DESCRIPTION A squeal noise may be heard when releasing the clutch (moving the vehicle from a stop or shifting gears). The squeal is caused by mismatched springs in the cushioning plate of the clutch. To prevent squealing, the thickness of the cushioning plate has increased. REPAIR PROCEDURE 1. Verify the complaint.
https://images.2carpros.com/forum/automotive_pictures/62217_mx3a_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_mx3b_1.jpg WARRANTY INFORMATION Applies To Verified Customer Complaints On Vehicles Covered Under Normal Warranty. Refer To The SRT Microfiche For Warranty Term Information. Warranty Type: A Symptom Code: 82 Damage Code: 9E Process Number: E4002A (323/Protege) E4001A (MX-3) Part Number Main Cause: See Parts Information Quantity: 1 Operation Number/Labor Hours: H0202ARX / 2.3Hrs. (323/Protege) H0202BRX / 4.0Hrs. (MX-3 with a K8 engine) H0202ARX / 3.1Hrs. (MX-3 with a B6 engine) NOTE: 1. The only repair for the clutch covered under the 36/50,000 warranty is "Clutch Squealing". No other clutch complaints are covered under this warranty. 1. Only clutch disc replacement is required for this repair. Replacement of the clutch cover is not covered under this repair.
Mar 21, 2009 at 2:09 AM
MERLIN2021
  • 17,250 POSTS
Or this MTX OVERHAUL INFORMATION - REVERSE GATE SPRING CARE TECHNICAL SERVICE BULLETIN Reference Number(s): CAT. J, NO. 003/97,  Date of Issue:   October 23, 1997 Related Ref Number(s): CAT. J, NO. 003/97 ARTICLE BEGINNING MXT OVERHAUL INFORMATION Model(s): 1990-94 Mazda Protege with OHC engine: 1990-94 Mazda 323 with OHC engine: 1995 Mazda Protege: 1992-94 Mazda MX-3: 1993-97 Mazda 626, MX-6 Category: J - Manual Transaxle Bulletin No.: 003/97 Date: October 23, 1997 DESCRIPTION During overhaul the reverse gate spring may be damage or dislodged due to contact between the reverse gate assembly and the differential assembly. See Fig. 1 . Care must be taken during differential assembly installation to prevent contact with the reverse gate assembly. To prevent the spring from dislodging the spring's end configuration has changed. Page 1 of 1 MTX OVERHAUL INFORMATION - REVERSE GATE SPRING CARE -1992 Mazda ...
https://images.2carpros.com/forum/automotive_pictures/62217_MX3c_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_mx3_1.jpg
Mar 21, 2009 at 2:12 AM
