1992 Mazda MX3 engine won start
COJI
Engine Mechanical problem
1992 Mazda MX3 6 cyl Two Wheel Drive Automatic 1ooo miles
my mazda mx3 wont start . it died on me on the free way and it had happen before and i got it started. but after the second one it would start.the engine is turning over but its not starting i kept tring it untill the battery runs out..what should i do
Feb 15, 2009 at 5:04 PM
  • 75,988 POSTS
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Feb 15, 2009 at 5:09 PM
