1989 Mazda MPV No Start
DLCARL
1989 Mazda MPV 4cyl 2w/d. My car quit while driving. It quit as though it ran out of fuel. I had it towed home. It sat for 2 hrs. I tried to restart, it started, but only ran for 1 or 2 seconds. No restart. Replaced fuel filter. Started briefly. No restart. Checked fuel pressure, it's fine. checked for spark, got blue spark. Sprayed small ammount of starting fluid into cylinders. fired briefly till fluid burnt off. Checked for spark again the next day. No spark. Tested coil with ohmmeter, failed primary resistance test. Replaced coil. No start & no spark. Had vehicle towed to repair shop. He got it running using my origional coil & told me the new coil was no good. Parts store tested it and said it was good. Anyway it ran for 2 days quit again and now Im back where I started. so far have replaced coil twice, new fuel pump, cap, rotor, and the pickup coil has been tested & passed. It ran great for those 2 days.
May 28, 2007 at 2:21 AM
DANCARLSON
  • 50 POSTS
Take out the fuel injector and clean the screens.
May 28, 2007 at 10:50 PM
DLCARL
[quote:d3acd1883c="DanCarlson"]Take out the fuel injector and clean the screens.[/quote:d3acd1883c] This has been done. Also cleaned throttle body. Checked for top dead center, replaced ECU with used (tested) unit. Checked & cleaned fuel pressure regulator,cleaned injectors. Sometimes get spark sometimes no spark. By the smell of the plugs there's no fuel being delivered. Stumped.
May 29, 2007 at 8:30 AM
DANCARLSON
  • 50 POSTS
You have got a real thinker on your hands. The only thing I can come up with is a fusible link or a wire that has broken off inside its casing. See if you can get a hold of a wiring diagram and look it over. If it were a newer vehicle everyone would be saying 'computer'. The fuel pump control unit may be a place to look for the fuel problem, a broken wire or a fusible link to the coil, a bad ground. You might find that you are looking at 2 different problems with 2 different solutions. The spark sometimes there sometimes not sounds like a broken wire. Sometimes it gets bumped and is making a connection other times the ends are too far a part to allow a current. I know that it sounds dumb but the wiring is almost 20 years old. I wish I could help more.
May 30, 2007 at 12:02 AM
2CARPRO JACK
  • 11,533 POSTS
I would go back to the module or pickup, electronics can fail intermittently.Test good one minute and not work the next
May 31, 2007 at 1:23 AM
Suggested Repair
Recheck the ignition module and pickup coil for intermittent failure. Electronics can test good one moment and fail the next, which matches the intermittent spark.
Conversation Summary
A 1989 Mazda MPV quit while driving as if it ran out of fuel, then would start only briefly or not at all. Fuel pressure, spark, coil, fuel pump, cap, rotor, injectors, throttle body, fuel pressure regulator, and a used ECU were checked or replaced, and the pickup coil passed testing, but spark remained intermittent and the plugs smelled of no fuel. After running for two days it quit again. The expert advised returning to the ignition module or pickup because electronics can fail intermittently.
