1998 Mazda MPV Surges When Hot
HENRYW
My 98 MPV 4x4 (160K) All-Sport surges badly while accelerating when hot - either after running a couple of hours in cool weather, or much faster when over 25oC. In the worst case, it becomes undrivable if more than the slightest acceleration is required (eg up hills!). If the vehicle is stopped for a few minutes, the problem temporarily disappears. The distributor was replaced by the Mazda dealer; it has had new fuel and air filters and been given a "super flush" of all lines and fuel injection assembly. I suspect either a fuel or air supply issue related to faulty control (thermostat?, computer? fuel pump?) but no errors are generated by the onboard computer and of course the problem is impossible to generate for the dealer who has been unable to suggest a cause! The water pump and fan clutch was replaced soon after we purchased the vehicle; I don't know if the problem was present before then, but the Mazda dealer denies it (we wonder if they damaged something during installation). ANY SUGGESTIONS PLEASE??
Dec 1, 2006 at 6:21 AM
CATCH_15
  • 250 POSTS
You could possibly have a leak through the intake manifold gasket which the computer can not account for which would be why you haven't gotten any trouble codes.
Dec 3, 2006 at 11:39 AM
COSMO
  • 347 POSTS
The intake is a good place to start, I would also be aware of some B.A.C. valce concerns on that vehicle.
Oh thats by-pass air control valve.
Cosmo...Mazda Tech
Dec 4, 2006 at 1:49 PM
Suggested Repair
Inspect for an intake manifold gasket leak the computer cannot compensate for, and check the bypass air control (BAC) valve, which has known concerns on this vehicle.
Conversation Summary
The owner of a 1998 Mazda MPV reports severe surging under acceleration when the engine is hot, with no trouble codes. A new distributor, filters, and fuel-system flush did not fix it. Experts suggest checking for an intake manifold gasket leak and bypass air control valve problems.
